Fluent journal file
I am trying to create a journal file in order to be able to set the memory usage of each solver processor used in fluent when I open fluent and the journal file from the command line:
fluent 3ddp -t2 -sl 1000 -i journal.jou Only problem is that I can't figure out how to set up the environment tab from the journal... I need the environment tab set up in order to be able to compile UDfs properly. /file/set-tui-version "20.1" ; Set up compilation environment for UDF (cx-gui-do cx-set-udf-compile-env #t) /file/read-case dp_3d_LH2_tank.cas.h5 (cx-gui-do cx-set-list-tree-s... this is what i had but it doesnt work, has anyone done this before? |
any reason to compile inside journal?
compile udf separately before actual simulation |
