heat transfer coefficient of air gap
Old   August 21, 2023, 01:59
Default heat transfer coefficient of air gap
Yakub
YAKUB A is on a distinguished road
I'm working in PMS motor. I need to find heat transfer coefficient of air gap between stator and rotor while rotor is rotating. I have made one fluid region in between stator and rotor and given solid rotation to rotor. Rotor and stator has source terms also. But it shows 0 pressure and velocity for the air gap.
Then made one MRF region around rotor and assigned as air. Given frame motion to MRF region, then it has pressure and velocity variations but heat transfer coefficient value is not convincing. Because air gap heat transfer coefficient found analytically using Taylor's correlations.
What mistake I have done, give me guidance to find heat transfer coefficient of air gap.
Fig1;Air gap. Fig2:mrf
YAKUB A is offline   Reply With Quote
Surface Heat Transfer Coefficient on a heated cylinder Alczem OpenFOAM Post-Processing 0 March 21, 2022 07:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Heat Transfer Coefficient of air vs Velocity shreesha87 Main CFD Forum 3 May 30, 2014 03:10
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
