[Sponsors] | |||||
Saeed Jamshidi
Rep Power: 9 ![]() |
I have simulated flow over cylinder in Re=200 in openfoam, and I have used snappyHexMesh, but it looks there are sharp variations in velocity field in the regions that mesh switches from one level to another. I have attached my mesh and velocity contour for your consideration. I know here is Ansys Fluent forum, but I hope you could helpe me on the basis of your experience in fluid mechanics. Thanks in advance. |
Kareem
Rep Power: 6 ![]() |
The change in mesh elements is too abrupt. You will need a more gradual transition from the larger elements to the small ones. Sharp changes in mesh size can lead to numerical error, which you are seeing in your simulation.
I am unsure of how to do this in Openfoam, but in Fluent you can use a "Growth Rate" which will smooth the transition between cells of varying size.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
| SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
| [snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
| fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
| Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
