Alessandro Pinciroli
Rep Power: 0 ![]() |
Hello, I want to simulate a gas release from a tank and I'm trying to refine the mesh within a certain velocity range. The problem is that when I define the cell register and I press "display" I can see the cells that need refining however when I press adapt the number of total cells doesn't change. I set up a minimum cell volume of 0.00001m3 and I surely got cells greater than that. If I lower the minimum volume it refines the smaller cells but not the bigger ones.
also, the cell refinement works for a while and then the cells number doesn't change like I said before. When I look at the mesh it seems that the refinement is not even, leaving bigger cells between smaller ones even if those are included in the refinement criterion. |
Display Modes | |
Fluent 2023 TUI Adaptive Mesh Refinement Commands | sabrinam97 | FLUENT | 0 | May 29, 2023 11:56 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
