Tyrmida |
October 10, 2023 14:49 |
Performance Issue - flmpi stops CX process busy
Good evening all,
I am hoping that someone can help me with direction with trying to figure out why a certain model may be performing slowly.
While solving (local single machine or over msmpi/ms job scheduler) the fl_mpi23* process works for a few seconds, but then stops until the next iteration.
In this "wait" period, the cx23* process is madly busy doing I don't know what - is there any way I can figure out what it is in fact trying to do?
Things we have tried:
- Local run only and also through MS Job scheduler (msmpi)
- Run without GUI or with
- Limiting CPU Cores Per Node different amounts from 4 to 40
- Limiting Nodes different amounts from 1 to 12
- Disabling dpm in the model
All other benchmarks that we have tried is performing 100%. Our system is 12 x nodes of dual 44-core Intel Xeon 6152 cpus with 6 memory channels per CPU. Storage is SSD. Network is 100gb IB.
The "Pausing" is reflected in the performance timer as the iteration supposedly takes 4 seconds but 30 iterations take 1276 seconds.
No errors in fluent output at all showing something is wrong. Disk queues empty. It seems that the "average wall-clock time per iteration" scales accordingly to number of nodes/cores given to the job, however the waiting still stays there.
If anyone can maybe suggest how we can figure out the root cause I'd really appreciate it.
Performance timer output:
Performance Timer for 30 iterations on 240 compute nodes
Average wall-clock time per iteration: 4.032 sec
Global reductions per iteration: 443 ops
Global reductions time per iteration: 0.000 sec (0.0%)
Message count per iteration: 760147 messages
Data transfer per iteration: 3612.734 MB
LE solves per iteration: 5 solves
LE wall-clock time per iteration: 0.607 sec (15.1%)
LE global solves per iteration: 2 solves
LE global wall-clock time per iteration: 0.025 sec (0.6%)
LE global matrix maximum size: 355
AMG cycles per iteration: 6.000 cycles
Relaxation sweeps per iteration: 436 sweeps
Relaxation exchanges per iteration: 0 exchanges
LE early protections (stall) per iteration: 0.000 times
LE early protections (divergence) per iteration: 0.000 times
Total SVARS touched: 398
DPM updates per iteration: 0.5000 updates
DPM wall-clock time per iteration: 1.334 sec (33.1%)
Time-step updates per iteration: 0.50 updates
Time-step wall-clock time per iteration: 2.448 sec (60.7%)
Total wall-clock time: 120.947 sec
Total dpm solve time: 40.029 sec
Total dpm i/o time: 0.000 sec
Simulation wall-clock time for 30 iterations 1276 sec
Thank you very much in advance
