Using results as initialization
Hello!
Could someone please help me with how I could use the results from one case as initial values for another case (with same geometry and same mesh)? I want to use the temperature on my structure as inital values for my other case with different boundary conditions. Thank you in advance :) |
file->export->solution data
Thank you Alexander!
How do I initialize my new case with the exported results? |
Hi, isaac_h!
I think you can just change the settings of the former case and calculate. |
Thank you very much, it worked perfectly :)
