[Sponsors] | |||||
eddy
Rep Power: 4 ![]() |
I am investigating the drag coefficient based on the Reynolds number.
In the laminar flow regime, I confirmed a reasonably good agreement for the drag coefficient through two-dimensional analysis. Now, as we move beyond laminar flow, turbulence occurs, necessitating three-dimensional analysis. Therefore, I conducted 3D simulations, taking into account Reynolds numbers that vary with the diameter D of the cylinder. However, while the diameter remains constant, the length of the cylinder does not influence the Reynolds number.(The frontal area varies with length.) Could you explain why the drag coefficient varies with spanwise direction in this case? Your insights on this matter would be greatly appreciated.
#2 | |
And very briefly speaking increase in reference surface area (S) would increase Drag force (N) with Q being dynamic pressure.
eddy
![]() The flow direction, as seen in the image, is along the x-axis. Additionally, the term "spanwise," mentioned in the text, refers to the z-axis. Naturally, as the spanwise dimension increases, the frontal area expands, leading to an increase in drag force (N), which is expected. What I am curious about is the drag coefficient. The drag coefficient varies with the Reynolds number in this scenario. However, what influences the Reynolds number in this situation is likely the diameter of the cylinder, not the length (spanwise). Thanks.
#4 | |
cd.png If Reynolds is same then Cd should not vary even if you increase area, because the increase in Area will be compensated by increase in pure drag force (N) thus balancing Cd.. |
#5 | |
eddy
In the images I provided, the diameter (D) of the cylinder varies with the Reynolds number. However, when keeping this diameter constant and only altering the height (length along the z-axis) of the cylinder in the simulation, the resulting drag coefficients are different. All simulation options were kept identical, with the only variation being the height of the cylinder. Thank you for your attention and consideration.
#6 | |
Lorenzo Galieti
Rep Power: 13 ![]() |
Ye, I am wondring the same thing. If you did not impose a symmetry condition, then the increase of length translates into a larger rectangular pipe with larger characteristic dimension, hence affecting the reynolds number of the flow.
Also, not sure how you are including turbulence? is this still "laminar" model, i.e. bare bone navier stokes? RANS? |
eddy
#9 |
Erik
Rep Power: 24 ![]() |
Repeating LoGal's question:
Also, not sure how you are including turbulence? is this still "laminar" model, i.e. bare bone navier stokes? RANS? What is your inlet turbulence specification? This could possibly be different depending on how you defined inlet turbulence if the length scale used to compute these values is different. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Simulation of flow past a cylinder | Ashkan Kashani | CFX | 6 | October 6, 2022 04:48 |
| How to approach CFD simulation results of the flow past a cylinder? | Ashkan Kashani | Main CFD Forum | 3 | February 7, 2022 03:46 |
| Problem of convergence- simulation of flow wind around cylinder | activo | FLUENT | 6 | October 23, 2015 02:57 |
| Flow Simulation : air around an rotating cylinder using Solidworks Flow Simulation | Wyrold | Main CFD Forum | 0 | October 22, 2015 09:48 |
| modification for rotating cylinder simulation | zonexo | Main CFD Forum | 3 | July 21, 2006 15:24 |
