[Sponsors] | |||||
Natural Convection with huge temperature difference (1000K) |
Clement
Rep Power: 3 ![]() |
Dear Fluent Community,
I am currently simulating air at rest confined in two concentric tubes with a constant heat condition on the inner radius and a convection condition characterised by a convective exchange coefficient. I have defined the thermal properties of air that change with temperature (density, heat capacity, conductivity, viscosity). The delta T is very large, almost 900°C in the real world. I've opted for a laminar model for viscosity. Is this correct? Do I need to change any other parameters? |
#2 | |
Kareem
Rep Power: 6 ![]() |
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
Clement
Thank you for your reply.
In my case, I opted for the Laminar solver. I have one last question to ask you. I think I'm getting good results, but one result worries me. When I increased the inside diameter to 22mm instead of 21mm, I got a temperature difference of more than 100°C. In reality, I've tested and we don't have a big difference as the simulation results tell us. I have no idea where the problem lies in my conditions/simulations. Do you have an idea ? Thank you in advance Last edited by clementbrun; March 6, 2024 at 10:00. |
Kareem
It's hard to say without knowing the exact experimental setup. On the outer radius I assume there is a solid wall. Since you are applying a convective heat transfer coefficient directly to the fluid domain it would likely overestimate the heat flux through this boundary. I would try either adding a wall thickness to the wall boundary or modeling the solid, assuming there is a solid wall on the outside.
Clement
Thank you very much !
Lorenzo Galieti
Rep Power: 13 ![]() |
I do not get how air at 1000K sits at rest near air at 300K and there's no circulating flow (like in a pot). Unless gravity is neglected
Clement
Hi, I probably misspoke. There is no air movement in the current system, the air is trapped. But in reality, yes, there are natural air movements. I observed this by making a contour of the speed and I could see the circulation of the fluid.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Diverging solutions for natural convection flow at differentially heated vertical wal | SonnyD | OpenFOAM Running, Solving & CFD | 0 | May 26, 2021 13:20 |
| whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
| chtMultiRegionFoam natural convection negative initial temperature | saidc. | OpenFOAM Running, Solving & CFD | 6 | February 9, 2021 07:14 |
| Problem with natural convection | claudia.h | FLUENT | 2 | July 3, 2012 04:10 |
| Natural convection problem in CFX 11 | Willy | CFX | 2 | May 24, 2008 00:12 |
