Varying results in fluent when varying mesh
Old   March 13, 2024, 17:44
Default Varying results in fluent when varying mesh
Mostafa Kamal
Moka is on a distinguished road
Hi everyone
My case is turblent and transient flow for simulations gas turbine in wind tunnel
Free stream velocity 33.5m/s and Re No. 5.6*10^5
When generate 1st case mesh general element size is 8.4mm and blade wall size is 3 mm with sweep method ;when run this case total pressure losses at outlet is 0.3
Than 2nd case when canceling sweep method in mesh and run case in fluent the total pressure losses at outlet be 0.36
Which result true?
Is that must make inflation or not ?
Moka is offline   Reply With Quote
[ICEM] Exporting good ICEM mesh to Fluent results in poor quality mesh balrog_f ANSYS Meshing & Geometry 3 October 17, 2021 03:43
Fluent Mesh Check Fail aunmhd FLUENT 1 August 9, 2020 07:23
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 22:41
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
