[Sponsors] | |||||
Insert transient table data in named expressions |
Rep Power: 0 ![]() |
Good morning, I am currently working on a project using Fluent 2019, where the main issue is to pick a heat source which is dependent from time and temperature. I uploaded a transient table containing different temperature ranges linked to different heat sources. I noticed that in recent versions, using an IF cycle in the named expressions I would be able to select the heat values contained in the different columns of the table, but using fluent 19, these values don't appear, is there any way to solve this? Thank you in advance
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| UDF value to large for defined data type | Anna73 | Fluent UDF and Scheme Programming | 9 | September 30, 2018 23:18 |
| [Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
| Animation of Fluent transient data | saisanthoshm88 | FLUENT | 2 | December 18, 2012 10:51 |
| interpolation table user function not loading data properly | cfdonlineuser | CFX | 2 | November 25, 2012 20:37 |
| Average of Expressions in Transient Run for Parameter Study | BigPapi34 | CFX | 1 | August 7, 2012 06:34 |
