[Sponsors] | |||||
Mostafa Kamal
Rep Power: 3 ![]() |
Hi everyone
My case is turblent and transient flow for simulations gas turbine in wind tunnel Free stream velocity 33.5m/s and Re No. 5.6*10^5 When generate 1st case mesh general element size is 8.4mm and blade wall size is 3 mm with sweep method ;when run this case total pressure losses at outlet is 0.3 Than 2nd case when canceling sweep method in mesh and run case in fluent the total pressure losses at outlet be 0.36 Which result true? Is that must make inflation or not ? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to perform larger deformations while mantaining good mesh with adjoint solver | FormulaStudentFEB | STAR-CCM+ | 0 | October 13, 2023 12:27 |
| flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
| how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
| [ANSYS Meshing] Airfoil edge sizing mesh generation problem | Kostas_K | ANSYS Meshing & Geometry | 0 | March 6, 2017 14:50 |
| fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
