Invalid Cp error at a specific temperature in Fluent
Old   March 15, 2024, 06:09
Default Invalid Cp error at a specific temperature in Fluent
MB
Mohamad.Baassiri is on a distinguished road
Dears,
I am simulating a free jet CO2 through a micro-orifice. I have supercritical upstream conditions, and subcritical downstream conditions. I am using Peng Robinson real gas equation. Model works perfectly fine as long as the inlet temperature is >310 K. If I reduce the the inlet temperature to less than that, the model diverges and I get the error 'Invalid Cp (- xxxxx) at T= xxxx'.
Note that I am starting from a converged solution at T=310 K, and slightly changing T to 308 K (for example). I understand that this is a pseudo-critical region where properties of CO2 vary abruptly. So my question is would someone kindly suggest how to deal with this issue in Fluent?
Thank you,
Mohamad.Baassiri is offline   Reply With Quote
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 07:35
Evaporation condensation below saturation temperature in FLUENT user321 Fluent Multiphase 1 January 29, 2020 06:41
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
