Ansys Fluent Non-Dimensionalizing CL By Wrong Area?
Old   May 2, 2024, 20:46
Default Ansys Fluent Non-Dimensionalizing CL By Wrong Area?
Joshua
JoshLaz is on a distinguished road
So I'm a very new user, I'm trying to self teach so please excuse my ignorance if I'm making particularly dumb/un-informed statements.
I've run Ansys Fluent for a wing, I used the symmetry axis setting (thus the forces will be for half the wing, correct?) in the enclosure tool, my problem is that the lift and drag coefficients don't seem to match up with my manually computed coefficients nor rough estimates from OpenVSP's VSPAERO results...
I have a NACA 2313 rectangular wing with chord of 6.67" and half span of 47". When I divide the forces (outputted by fluent) by the dynamic pressure and the half area (chord * half span (converted to m^2)) I get coefficients of lift that match the expected results from VSPAERO (image of those results attached). However the values for the coefficient of lift outputted by fluent directly seem completely arbitrary, when I multiply them by the area and dynamic pressure they don't even give me the forces that fluent itself output...
I've attached an excel file with my results in it, you'll see the output CL under the column labeled "CL" and the calculated CL under "CL Calc".
Any help would be much appreciated, again my apologies if this is a dumb question.
JoshLaz is offline   Reply With Quote
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
How to calculate area of this colored area in result ansys fluent ? Sai D Irfan FLUENT 0 June 24, 2020 21:52
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 16:30
