Simulation of flow around an impeller in a large closed cavity
Old   June 30, 2024, 02:47
Default Simulation of flow around an impeller in a large closed cavity
Sadafi
Sadafi is on a distinguished road
Hi all
I wanna simulate flow around an impeller located in a large closed cubic cavity filled with low-pressure air. The impeller is rotating and there is no inlet or outlet from the cavity. Is it possible to simulate it with fluent and if so, which boundary conditions should be set?
Thank you in advance
Sadafi is offline   Reply With Quote
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
How to manage the pressure term in fixed mass flow rate based channel flow simulation sjwon1991 Main CFD Forum 5 July 10, 2017 08:21
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Closed domain compressible flow simulation Vaaj FLUENT 2 May 7, 2017 20:38
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
