[Sponsors] | |||||
Leyton
Rep Power: 0 ![]() |
Hello. I am doing my final degree project and it is based in modifying the geometries of bipolar plates and see how it affects the fuel cell performance.
Firstly, I have already made the geometry modifications and have also done the meshing and import to fluent module. The setup of the PEMFC has been correctly done but, now, once I have changed the inlet flows, current density on cathode looks like this: Attachment 100955 The red arrows shape is the cathode's shape and I dont know how can it be possible if I have only changed the inlet flows. Without the changes in inlet flows it looks like this: Attachment 100957 Attachment 100958 The data for the inlet flows has been taken from the ansys tutorial for PEMFC (anode inlet: 1e-7 [Kg/s]; cathode inlet: 1.4e-6 [Kg/s]), while the data I have been using has been obtained from an European Document for PEMFC automotive applications: Attachment 100959 With this data you can get the inlet flows with the calculator included in the PEMFC module in Fluent for a desired current, for example: Attachment 100960 I would apprecite some answers, thank you! |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Current density for solid oxide electroyser | lavendar12 | FLUENT | 0 | December 6, 2023 07:32 |
| How to change air density to zero | pinpin | OpenFOAM Running, Solving & CFD | 5 | August 25, 2021 08:13 |
| GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 08:48 |
| density change with pressure | chem engineer | FLUENT | 3 | September 26, 2015 11:57 |
| No density change - rhoSimplecFoam | krapic | OpenFOAM | 1 | November 29, 2014 19:39 |
