Particles injected in clustered lines
Old   September 4, 2024, 10:35
Default Particles injected in clustered lines
Livingstone Quarshie
lquarshi is on a distinguished road
I am injecting particles using the surface injector, and with the parcel release type I used number of particles. I then put in the number of particle in a parcel which is 0.998. I read in the manual that number of particles in a parcel could be an integer, which makes it better to inject required of particles to meet the expected total mass of particles.
I am using the Rosin-Rammler distribution. During the post-processing, I was hoping to see single particles going through the domain but I see about 3-4 particles clustered. When I zoom out I could see they are individual particles clustered in line. I don't see any injection when I use the stagger-option.
What could be the cause of this that the particles are being clustered in line?
I have attached some pictures for my set up.
lquarshi is offline   Reply With Quote
UDF for deleting particles in DPM imanmirzaii Fluent UDF and Scheme Programming 12 November 25, 2020 20:27
[DPM-UDF] Re-injecting escaping particles at different position CeesH Fluent UDF and Scheme Programming 7 May 13, 2020 11:34
UDF for assigning particles position (re-injecting to the inlet) cicatrix Fluent UDF and Scheme Programming 0 November 11, 2019 08:11
Nitrogen injected into a column filled with sand particles AndoniBM OpenFOAM 1 April 10, 2015 06:57
lost 60 new injected particles on last node diamondx FLUENT 4 April 15, 2014 14:01
