Realizable k-e Turbulent viscosity UDF
Old   October 15, 2024, 06:26
Default Realizable k-e Turbulent viscosity UDF
Anh
dinhanh is on a distinguished road
Hi Fluent Experts,
I am trying to write a UDF for the turbulent viscosity based on the Realizable k-e model (See the Figure below).
The UDF code is for 2D simulation, and I had trouble defining the term W. The code got an error when it compiled.
Is the definition of W correct? Thank you very much for your help.
The UDF code is:
#include "udf.h"
DEFINE_PROPERTY(tur_vis,c,t)
real mu_tur;
real Sii, Sij, Sjj, Wij, Wijr;
real SMU, WAS, PHI, USTAR;
real AS;
real CMU, y, a1, a2, a3, a4, a5, a6;
real betas=0.09;
real A0=4.04;
real wr=11.7 /***rotational speed***/
/*** Cal Sij and Wij
Sii=0.5*(C_DUDX(c,t)+C_DUDX(c,t));
Sij=0.5*(C_DUDY(c,t)+C_DVDX(c,t));
Sjj=0.5*(C_DVDY(c,t)+C_DVDY(c,t));
Wij=0.5*(C_DUDY(c,t)-C_DVDX(c,t));
/*** Cal vorticity with rotational rate ***/
Wijr=Wij-wr*C_D(c,t);
/*** Cal U* ***/
USTAR=sqrt(Sii*Sii+2*Sij*Sij+Sjj*Sjj+Wijr*Wijr);
/*** Cal Phi ***/
SMU=sqrt(Sii*Sii+2*Sij*Sij+Sjj*Sjj);
WAS=(2*Sij+Sii+Sjj)/pow(SMU,3);
PHI=1/3*pow(cos(sqrt(6)*WAS),-1);
/*** Cal As ***/
AS = sqrt(6)*cos(PHI);
/*** Cal CMU ***/
CMU=1/(A0+AS*USTAR/betas/C_O(c,t));
mu_tur=C_R(c,t)*pow(C_K(c,t),2)/C_D(c,t)*CMU
return mu_tur;
File Type: jpg 2b1f3f2e-454c-4fc5-9855-1e54848f22fe.jpg (36.9 KB, 1 views)
dinhanh is offline   Reply With Quote
Turbulent viscosity for transitional SST model in ANSYS Fluent Bovinille Fluent UDF and Scheme Programming 0 October 11, 2023 14:19
UDF Turbulent Viscosity Damping Function Revolver2006 Fluent UDF and Scheme Programming 11 July 12, 2017 15:40
wrong results after use UDF turbulent viscosity lehoanganh07 Fluent UDF and Scheme Programming 0 July 21, 2014 12:12
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
UDF of Turbulent viscosity justin FLUENT 0 November 24, 2006 07:36
