How to post process fluent files with high number of elements in Less RAM PC
Old   January 11, 2025, 01:56
Default How to post process fluent files with high number of elements in Less RAM PC
RV
Rahul Vishwakarma is on a distinguished road
I am trying to post-process a mesh file with 30 million elements in a 16 GB RAM system, But it shows a Memory allocation error. Is there any way to resolve this, apart from increasing RAM?
Rahul Vishwakarma is offline   Reply With Quote
Old   January 16, 2025, 14:09
Refik
rewol is on a distinguished road
I would only export the data that i intend to post-process later after running the solver to keep the size of ".dat" file small. For example, u,v,w velocities, pressure, temperature etc.
rewol is offline   Reply With Quote
Old   January 18, 2025, 01:01
Default Extra ideas
Hector Maldonado
DigiHctrGT is on a distinguished road
As pointed out above, I'd proceed like that and explore some alternative software solutions such as Paraview. For that, you could export .encas files linked to the variables you want to analyze as pointed out before. Check the Documentation for the procedure to export ascii or ensight-gold (.encas) files.
DigiHctrGT is offline   Reply With Quote
cfx & fluent, fluent, fluent - parallel, malloc storage
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
Seakeeping Solver:Crashed akbarbagusd Fidelity CFD 0 November 5, 2021 13:42
[Other] Equal decomposition of cylindrical fluid domain Sean95 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2019 04:34
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
