Regarding the use of in-built compiler in ANSYS Fluent 2021R |
Heer
Rep Power: 6 ![]() |
Hello everyone!
I am using ANSYS Fluent 2021R and I am trying to compile a UDF with the inbuilt compiler. But it is showing me the following error: scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly A warning: C:\PROGRA~1\ANSYSI~1\v211\fluent\ntbin\clang\10\In clude\10.0.18362.0\shared\basetsd.h(322,12): warning: cast to 'void * __ptr32' from smaller integer type 'unsigned long' [-Wint-to-void-pointer-cast] return((void * POINTER_32) (unsigned long) (ULONG_PTR) p); Additionally, I tried installing Visual Studio 2019 and 2022, but I guess that is not supported by 2021R. Can anyone please help me out what can be the possible solution to this? Thank you in advance! |
compiler, udf |
Display Modes | |
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? | Ryan T | ANSYS Meshing & Geometry | 3 | November 3, 2021 15:44 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
