Simulation Diverges depending on parallel process count
Old   February 6, 2025, 11:55
Exclamation Simulation Diverges depending on parallel process count
karam_j is on a distinguished road
Hello, i am running a simulation with UDFs that converged properly when using 4 cores/processes and the results are sensible.
Running the same case using the same settings with 0 changes on any other number of cores causes divergence within the first couple of iterations.
Does anyone have any idea what could be happening here? Thank you in advance.
karam_j is offline   Reply With Quote
cores, divergence, fluent, parallel, udf code
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Fluent simulation in parallel is slower on workstation than laptop?!!?! losiola ANSYS 5 November 4, 2022 09:56
Parallel fluent process exiting before reading the mesh file harsha2398 FLUENT 3 December 29, 2020 01:58
retrieve F_UDMI value in parallel mode asking Fluent UDF and Scheme Programming 0 October 16, 2019 09:48
OpenMPI error at the beginnin of parallel OpenFOAM Simulation tre95 OpenFOAM Programming & Development 2 June 17, 2019 07:36
