Mr.HydrodynamicSelect
Rep Power: 2 ![]() |
Hello everyone,
A question that may be obvious to someone (other than me): Do you need boundary layer mesh for laminar flow in fluent even if your results show that the mesh is sufficiently fine? (i.e. mesh convergence study has been completed) |
Zhang Haosen
Rep Power: 6 ![]() |
There is a boundary layer whether the flow is turbulent or laminar, and a local refined mesh is needed to resolve it.
Rep Power: 4 ![]() |
It depends on the need. Fine mesh near surface is needed for resolving the effects of boundary layer. Anything regarding calculation of heat transfer, mass transfer and hydrodynamic effects for fluid-solid interaction will be done by boundary layer calculations. If you only need to see the bulk fluid behaviour, you might not need it. But its is still a good practice to use finer mesh near surfaces as it reduces numerical diffusion and helps stability.
boundary layers, cfd, fluent, mesh |
Display Modes | |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
