I am simulating a nozzle flow where the nozzle lies in a confined region ( a type of coffin). The outer wall is offset from the center-line. When the nozzle exhaust flows the outer wall gets a very little influence of plume. However, the region just above the nozzle and (between the wall) s specified as pressure outlet. So i am running gauge values so only inlet pressure is specified while the press outlet is set to 101325 Pa and the operating pressure is set to 0. Solution diverges after aprrox. 500 iterations. I am using Coupled Method with pseudo time step with times step size to 0.05-0.1. Regards, SJ |
#2 | |
Please help me in this regard. I need it urgent pls
Display Modes | |
Simulating Piston Effect in Underground Metro Tunnel- Ansys CFX Tutorial | anoopjangra | ANSYS | 0 | April 2, 2020 04:41 |
Plume Entrainment - Finite Difference Solution | HumanistEngineer | Main CFD Forum | 0 | September 19, 2018 08:55 |
Air entrainment models - what's available? | TullyK | Main CFD Forum | 0 | May 11, 2017 05:22 |
Sediment entrainment | malugrave | Main CFD Forum | 0 | January 25, 2017 07:35 |
Air entrainment model setup for spillway | oajor | FLOW-3D | 4 | November 17, 2016 12:02 |
