Rotating Fluid Zone Errors in Vortex Simulation
Old   March 4, 2025, 16:23
Default Rotating Fluid Zone Errors in Vortex Simulation
Eddy L
discoed89 is on a distinguished road
Hi everyone,
I’m working on a **vortex simulation inside a jug for frothing** using **ANSYS Discovery**, and I’m struggling with the **Rotating Fluid Zone setup**. I’ve run into multiple errors, and I need **step-by-step guidance** to resolve them.
### **🚨 Errors I'm Facing in ANSYS Discovery:**
1️⃣ **"Rotating Fluid Zone Wall must be placed on faces with co-linear centers."**
- I believe this means my **rotation axis is misaligned**, but I don’t know how to check or adjust it properly in **Discovery Geometry or Setup**.
2️⃣ **"Motion for Rotating Fluid Zone Wall on cylindrical walls must have parallel axial directions."**
- I assume this means the **rotation axis isn't correctly defined**, but I don’t know where to verify or fix this in Discovery.
3️⃣ **"Motion for Rotating Fluid Zone Wall on planar walls must be aligned with plane normals."**
- It seems Discovery doesn’t allow rotation on **flat surfaces**, but I’m unsure how to define the right motion constraints.
### **🔹 My Current Setup & What I’ve Tried:**
✅ **Software:** ANSYS Discovery (2024 R2)
✅ **Project:** Simulating vortex formation inside a jug used for **frothing**
✅ **Geometry:** Created in **Discovery Geometry**, sent to **Physics Setup**
✅ **Fluid Volume Extraction:** Used **Volume Extract** to isolate the internal flow region
✅ **Rotating Fluid Zone:** Defined in **Physics Setup**
✅ **Moving Wall Boundary Conditions:** Assigned to the inner walls
✅ **Rotation Axis:** Checked in Discovery, but still getting errors
### **🔹 What I Need Help With:**
🔹 **Step-by-step troubleshooting** for these errors
🔹 How to **check and correct rotation axis alignment** in Discovery
🔹 How to properly assign **rotating wall boundaries** for a vortex simulation inside a **sealed jug**
🔹 Recommended **Discovery Physics settings** for **rotating liquid flow in an enclosed volume**
If anyone has experience with **vortex simulations in ANSYS Discovery**, especially for **frothing applications**, I’d love to hear your advice! 🚀
Would really appreciate any help! Thanks in advance! 🙏
discoed89 is offline   Reply With Quote
ansys discovery, cfd simulation, rotating fluid zone, vortex flow
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 09:49
[Commercial meshers] Unknown error when converting fluent mesh to openfoam Yutao OpenFOAM Meshing & Mesh Conversion 0 April 23, 2023 02:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 15:37
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 09:40
