Nozzle flow exit into confined region-with entrainment effect
Old   March 4, 2025, 19:42
Default Nozzle flow exit into confined region-with entrainment effect
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I am simulating a nozzle flow where the nozzle lies in a confined region ( a type of coffin with open exit). The outer wall is offset from the center-line. When the nozzle exhaust flows the outer wall gets a very little influence of plume. However, the region just above the nozzle and (between the wall) is specified as pressure outlet. So i am running gauge values so only inlet pressure is specified while the press outlet is set to 101325 Pa and the operating pressure is set to 0. Solution diverges after aprrox. 50 iterations. I am using Coupled Method with pseudo time step with times step size to 0.05-0.1.
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 12:16
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
Velocity-inlet boundary condition for flow exit Manu4CFD FLUENT 7 March 23, 2019 06:05
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
