Fluent SOFC - SOEC: OCV unrelated to fuel composition
Old   March 5, 2025, 11:03
Default Fluent SOFC - SOEC: OCV unrelated to fuel composition
Benjamin Ortner
ortb is on a distinguished road
Hello Fluent forum,
I need help with the Solid Oxide Fuel Cell with Unresolved Electrolyte Module. I have a validated SOFC case where the OCV is calculated correctly.
When enabling electrolysis mode, the model runs without errors, at least at a first glance
— H₂ is produced, and H₂O is consumed as expected. However, the OCV appears independent of the inlet species concentrations. For example, both 10 vol% H₂ / 90 vol% H₂O and 50 vol% H₂ / 50 vol% H₂O yield the same OCV of 0.977 V, which seems incorrect.
Besides enabling Electrolysis Mode, are there additional settings I need to adjust when switching to electrolyis? I've already tried modifying:
Anode/cathode inlets
Electrolyte wall and shadow
Boundary conditions
None of these changes improved the result.
It seems many have had a similar problem, but the answer was never properly stated. Any hints or suggestions would be greatly appreciated!
Thank you in advance!
Best regards,
Benni
ortb is offline   Reply With Quote
Old   March 11, 2025, 03:55
Default Solution
Benjamin Ortner
I found the solution. You can not prescribe the current density = 0 in electrolysis mode, because in the UDF, the voltage calculation is independent from the species calculation (Q=1).
Instead you are supposed to apply a voltage in excess of the OCV only. Then the current calculation is correct.
electrolysis, fluent, soec, sofc
fuel cell simulation in Fluent Huang FLUENT 19 July 2, 2024 09:04
fluent 19.2 sofc module initialization lbj007 FLUENT 12 July 19, 2022 08:41
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 12:16
SOFC modeling setting in fluent miladebadi FLUENT 0 February 24, 2017 03:01
FLUENT FUEL CELL MODEL BC FLUENT 6 November 22, 2016 01:24
