Error when generating meshes
Old   March 5, 2025, 16:56
Default Error when generating meshes
Mahmoud
Mahm0ud is on a distinguished road
I am a new user to Ansys Fluent.
I have generated the geometry and also generated the mesh, but when I try to update the mesh, I receive this below message.
(Update failed for the mesh component in the fluid flow (Fluent). Error updating cell mesh in the system fluid flow (fluent))
Any idea how to solve this?
Mahm0ud is offline   Reply With Quote
Old   March 6, 2025, 00:51
Kadari Mahesh
MAHESH9966 is on a distinguished road
Can we have what is the exact geometry you are meshing? Did you apply any periodic boundaries? if yes please check with interface matches exactly or not.
May be i am not that much expert but If you can elaborate about your model may one of the member can help you in this issue.
Thanks in advance
MAHESH9966 is offline   Reply With Quote
Old   March 7, 2025, 20:27
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
try to create another bllockl of mesh only. Drag the geomtery cell to this new one and create the mesh then create a separate block of only Fluent. Then export the mesh cel to this fluent cell
Shamoon Jamshed is offline   Reply With Quote
[Other] Generating hex meshes STutexas OpenFOAM Meshing & Mesh Conversion 1 February 24, 2016 03:55
generating OpenFOAM meshes with pointwise robo OpenFOAM Pre-Processing 1 April 29, 2014 14:47
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 04:16
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 23:26
