Obtaining Full Developed Flow while having zero static pressure at inlet
Old   March 6, 2025, 02:43
Default Obtaining Full Developed Flow while having zero static pressure at inlet
Aykut Gunhan
agunhan is on a distinguished road
Hello everyone,
I have been studying on rayleigh step bearing for a while. Most of the approaches to solve the problem includes Reynolds' Equation. What I want to do is solving the same problem with full NSE. Regarding the nature of the problem, I need to have a fully developed flow at inlet while having zero statik pressure at the inlet. In this way, I expect to see a pressure distribution starting from zero to max value at step and then decrease to the zero until the outlet.
In literature, I have seen different approach both Reynolds' eq and NSE, and they were able to obtain this distribution. However, as far as I know it is not possible to force the inlet with both pressure and velocity input.
Is there any way that I can obtain this kind of distribution on ANSYS Fluent?
The work principal relays on zero-gauge pressure inlet and outlet (p1=p2) and all the flow movement are caused by moving wall on bottom. Top is no-slip stationary wall.
thank you,
agunhan is offline   Reply With Quote
ansys, fluent, hydrodynamic-force, rayleigh-step-bearing
What is difference between static pressure and gauge pressure? aja1345 FLUENT 2 May 28, 2025 03:07
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Pressure Inlet: question about total pressure I-mech FLUENT 0 July 13, 2014 06:38
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
