ANSYS Fluent Interface
Old   April 5, 2025, 09:56
Default ANSYS Fluent Interface
Jmski is on a distinguished road
Hi everyone,
I’m currently using ANSYS Fluent 2025R1 and everything worked perfectly fine until yesterday. Since then I have problems with the interface.
When I open Fluent, it loads the case files correctly, but the interface is missing several elements:
- The Outline View panel on the left does not appear.
- The top menu bar is completely gone.
Only the task page, the user window, and the console are shown (as in the attached picture https://imgur.com/a/rLYgGpY ).
So far I’ve tried the following:
- Restarting Fluent and reloading the case/data files.
- Reinstalling ANSYS.
There are no errors shown in the console or logs. Fluent itself works fine otherwise – this only affects the visualization window.
Has anyone experienced this or knows a solution? Any suggestions would be really appreciated!
Thanks in advance.
Jmski is offline   Reply With Quote
Old   August 28, 2025, 21:00
J. C.
Yankee1105 is on a distinguished road
Hey, Do u find a solution?
Yankee1105 is offline   Reply With Quote
Old   October 7, 2025, 08:07
hozctn is on a distinguished road
Hey,
In your user's directory, there must be a configuration file named as ".cxlayout.ini". Delete that file and restart the fluent, that should work.
hozctn is offline   Reply With Quote
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? Ryan T ANSYS Meshing & Geometry 3 November 3, 2021 16:44
UDF to track the interface in VOF method in Ansys Fluent radin_85 Fluent UDF and Scheme Programming 3 July 6, 2021 17:11
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
