Efficiently changing many BC types in a PyFluent script
Old   May 14, 2025, 19:41
Question Efficiently changing many BC types in a PyFluent script
Bryan
br35cu29 is on a distinguished road
Hi all!
I'm using PyFluent to launch Fluent and automate my setup.
My project involves simulating chillers on a roof. I am representing airflow through the chillers with recirculating inlet and outlet boundary conditions. As far as I am aware, the only way to enable this feature in Fluent is by entering the following two commands through the TUI:
(rpsetvar 'icepak? #t)
(models-changed)
I can set and change common boundary types simultaneously for multiple surfaces quite easily in Fluent Meshing, but I can't find recirculating conditions there. So, in my PyFluent setup script, I change the necessary boundary types using the following example command:
solver.tui.define.boundary_conditions.modify_zones .zone_type('my_boundary_name', 'recirculation-inlet')
The challenge I'm encountering is that I have hundreds of recirculating inlet-outlet pairs. Changing boundary types in Fluent not only appears to be a slow process, but it also scales exponentially with increasing numbers of boundaries to change. For example, when I tried to change ~800 boundaries in a for-loop, it took about 175 seconds to change each boundary; on track to complete the loop after ~44 hours. After grouping some boundaries together so that I only had ~90 boundaries to change, it was taking only 16 seconds to change each boundary; on track to complete after <20 mins.
In my current project, I have ~350 boundaries to change, which takes about 5 hours. This is right on the edge of what is feasible given the number of models I need to setup.
Using either Fluent, Fluent Meshing, or the traditional Ansys Mesher, is there a more efficient way to change these boundaries?
Much appreciated!!
br35cu29 is offline   Reply With Quote
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
[ICEM] Generalize ICEM script for different sizes of same geometry. Akash kumar ANSYS Meshing & Geometry 0 November 16, 2014 09:38
Changing Boundary Types otq OpenFOAM Pre-Processing 0 October 8, 2013 13:00
[swak4Foam] a script for changing variables in groovyBC in 0 folder immortality OpenFOAM Community Contributions 38 July 22, 2013 18:57
changing the names and types of a boundaryField gerado OpenFOAM Running, Solving & CFD 0 March 24, 2009 09:55
