Dynamic Mesh - Fluent - Remeshing + Smoothing - Injector - BL problems |
Rep Power: 0 ![]() |
Hi all!
I have a quite tricky problem related to the Dynamic Mesh Metod available in ANSYS Fluent. I'm working on this "task" since 2 months, but I still have to solve one problem with my Dyn Mesh. I have to simulate the opening and closing of an injector (I have a profile .prof that prescribes the movement of the rigid body - needle) with the smoothing and remeshing methods (NO LAYERING). The main problem is the gap between the body of the injector and the needle: the gap between the two grows, so there I need new cells. I start with a quite good mesh (tetrahedral elements due to the remeshing) with a gap of 10µm. Here I have the 5-10 layers each wall + 1-2 layers of cells between them. When I go to ANSYS Fluent, I split my mesh in different zones in order to give them a movement/deformation/... Everything works, except the BL in the gap: it does not grow as I'm expected. In the pics, there is the result for a spring coeff = 0 (the BL can only smooth and not remesh). If the spring coeff = 1, the BL on the other side has this behavior. I also have some problems in the zone where the conical and cyilindrical parts of the needle get in contact: generally, they collapse. At the moment I'm moving the BL of the cylindrical part of the needle with a rigid movement, but there the BL will always remain super small and it's not a good solution. If someone of you have an idea of how to solve this problem, I'd be the happiest person in the CFD World Thanks Arianna |
boundary layer, dynamic mesh, remeshing, smoothing |
Display Modes | |
Mesh Disappering with Dynamic Mesh | FaroukH | FLUENT | 0 | February 23, 2021 18:26 |
Mesh Quality is not improving after Dynamic Remeshing! | shivasluzz | CFX | 9 | February 3, 2016 07:02 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Problems w 2d mesh conversion for Fluent | Gimlas | FLUENT | 1 | May 9, 2013 04:18 |
Dynamic mesh in Fluent to study tire in contact with road surface | lihuang | FLUENT | 10 | March 8, 2011 10:21 |
