Planes in Fluent
Old   May 23, 2025, 14:12
Default Planes in Fluent
Jessica
Jessica@123 is on a distinguished road
I'm facing this really annoying problem with fluent where I’m trying to create a plane at the throat of a bell nozzle engine, which is inclined at an angle relative to the X-axis. My geometry is a 3D half-model of a bell nozzle, cut along the XY plane, with an external domain to represent the environment. This setup shows then half of the engine from the inlet to the nozzle exit (I've half of inlet, throat and nozzle exit) inclined at an angle.
When I create a plane using the default XY, YZ, or ZX orientations and apply an area-weighted average, the results are not accurate because the plane intersects both the nozzle geometry and the external domain. As a result, the values include contributions from the environment, which I want to avoid.
How can I create a surface or plane exactly at the throat cross-section and at the nozzle exit — aligned with the nozzle's inclination — such that it only includes the internal flow domain of the nozzle and excludes the external environment?
Jessica@123 is offline   Reply With Quote
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 12:16
Running Fluent from Python: UDF Compilation problems Ames Fluent UDF and Scheme Programming 5 November 16, 2020 06:12
How to Monitor Planes in Fluent Automatically? epaj95 FLUENT 0 September 28, 2020 06:53
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
