Fluent simulation crashing when using auto-export
Old   July 10, 2025, 00:44
Unhappy Fluent simulation crashing when using auto-export
xDieseL is on a distinguished road
Hi all,
I am running some VOF simulations, and would like to export the pressure, velocity, and volume fraction data every 5 timesteps. I am using the Automatic Export option to get this data in CGNS format, so I can process it on ParaView. The simulation is to run for 4500 timesteps using the adaptive time stepping method (min timestep size is a microsecond).
The issue is that when I set up this export, the simulation abruptly ends and it sends me back to the Workbench window; the Fluent window is gone! No error, too...
I ran the simulation without the automatic export, and it works. I have exported data in the CGNS format for a similar simulation in the past, so I don't quite know what is causing this now.
Please advise.
Thanks!
Update: Importing the case file in another project altogether fixes the issue. It is working now!
UPDATE: IT STILL ABRUPTLY STOPS!
xDieseL is offline   Reply With Quote
Old   July 16, 2025, 08:41
Moritz Kuhn
MKuhn is on a distinguished road
Could be a file name issue? Do not use spaces and special character in your path.
MKuhn is offline   Reply With Quote
Old   July 16, 2025, 10:00
Hey MKuhn,
I, too, suspected that was the issue. The name i give it doesn't have any special characters or spaces. But the name that Fluent gives the file (in the Save As dialog box) has "Setup-Output" appended to it when I reopen Fluent. If I copy this name, it still abruptly ends.
I also noticed this only happens when exporting in CGNS format. EnSight Case Gold format saves with no issues!
crash, fluent
Ansys Fluent crashing when starting simulation marccfd25 FLUENT 3 July 27, 2022 10:02
Fluent crashing with no error message when initialising simulation with new UDF's ham551 Fluent UDF and Scheme Programming 1 October 27, 2021 14:54
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Courant number alert/pause simulation in fluent 2d aarratia FLUENT 1 April 16, 2015 03:07
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
