How to Transform 3D heat transfer problem to 2D
Old   September 6, 2025, 22:39
Post How to Transform 3D heat transfer problem to 2D
Mohsin
Mohsin1 is on a distinguished road
I need to model the dissipation of 180 kW of heat. I plan to simplify this from a 3D problem to a 2D analysis and define a heat flux boundary condition in Fluent.
My calculation for the original 3D case gives a heat flux of 2069 kW/mē, which I found using the formula: 180 kW / (0.025 m * 3.48 m).
For the 2D model in ANSYS, I created the mesh by extruding the geometry by a single cell's thickness in the direction normal to the screen. I applied symmetry boundary conditions to the front and back faces.
I am unsure what value to use for the heat flux on the bottom face in this 2D simulation (also, should the heat flux be defined on the bottom face of 2d problem or bottom front edge?). I have attached a picture for reference. Any suggestions would be appreciated.
Mohsin1 is offline   Reply With Quote
Old   September 10, 2025, 03:18
Moritz Kuhn
MKuhn is on a distinguished road
You can proceed in the same way as for the 3D model, that means define the inlet and outlet in the same way (not with symmetry). If you define under Physics --> Reference Values.. --> Length [m] = 3, you get your right value for the heat flux in W/mē, as you can not define it in W/m in the boundary conditions, as it will be for the 2D modell.
MKuhn is offline   Reply With Quote
fluent, heattransfer
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
complex impinging jet heat transfer problem spelletier Main CFD Forum 7 July 10, 2019 05:31
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
