Getting Fluxes in Fluent Parallel Mode through UDF
Old   September 26, 2025, 03:38
Default Getting Fluxes in Fluent Parallel Mode through UDF
yahale
yayale is on a distinguished road
I am trying to compute mass flow rate through many boundaries in my geometry.
Unfortunately, the UDF is not being able to address the faces (boundaries through which I need the fluxes), not sure why. Although tried many ways.
Computing these fluxes through Fluent GUI (Report -> Fluxes) is working and giving nonzero values.
Only the fluxes computed in the UDF are being zero.
Attached is the sample code used in the udf.
The simulation is being run in parallel mode.
Any idea how to solve that ?
yayale is offline   Reply With Quote
boundary, fluent, flux, parallel, udf
Fluent automatically switched to parallel mode rahulmule797@gmail.com Fluent UDF and Scheme Programming 2 November 5, 2019 04:38
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 07:23
PROBLEM in UDF on parallel fluent mode rakadit Fluent UDF and Scheme Programming 0 July 13, 2012 07:51
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
