[Sponsors] | |||||
Help - Heat Transfer of Supersonic Flow over Flat Plate |
Sophie
Rep Power: 0 ![]() |
Hello!
I am currently trying to simulate laminar Mach 2 flow over a flat plate in Fluent. I am specifically trying to obtain qw values over the length of the plate, which seems easy enough to do using the XY plot. However, I'm getting what seems like terribly unrealistic values for qw, max around 1.9e8 W/m2 at the leading edge. I want to observe how the fluid transfers heat to the plate, but this seems quite high. I am unable to find any issue with my boundary conditions (shown below) and I believe my mesh to be refined enough near the wall, though perhaps that may be the issue. Mass flow through the inlet/outlet and averaged enthalpy at the inlet have converged perfectly, with residuals past 1e-6. Has anyone experienced a similar problem where results seem accurate except seemingly for the heat transfer only? Any tips would be greatly appreciated, and if any other info is needed let me know. Plate geometry and conditions are taken from CFD by Anderson, Chapter 10, save for changing M=4 to M=2 Inlet: Velocity inlet, uinf = Mach 2, Tinf = 288.16 K, P = 101325 Pa Outlet: Pressure outlet, T = 288.16 K, P = 101325 Pa Wall: No-slip, isothermal, Tw = 288.16 K Farfield: Pressure farfield, uinf = Mach 2, Tinf = 288.16 K, P = 101325 Pa Last edited by sophiec5150; September 27, 2025 at 21:16. Reason: Clarifying geometry and providing source for problem |
| Tags |
| flat plate, fluent, heat transfer, laminar flow, supersonic |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Divergence Problem in supersonic Laminar flow over a flat plate | bgulzar22 | SU2 | 2 | September 20, 2023 04:00 |
| mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
| heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
| Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
| Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
