[Sponsors] | |||||
Fluent MHD/Potential Tab disabled for Electric Potential |
Junseong Kim
Rep Power: 0 ![]() |
Hello everyone,
I am trying to set up a transient Joule heating simulation in Ansys Fluent 2024 R1, but I am facing a persistent issue where I cannot apply the voltage boundary condition. I would be very grateful for any help or insight. I want to simulate Joule heating in a solid conductive part. I am trying to use the MHD Add-on Module with the Electrical Potential method. After setting everything up, when I go to Boundary Conditions -> Edit... for the wall where I want to apply voltage, the MHD (or Potential) tab is grayed out (disabled), so I cannot input a voltage value or hook my UDF. Ansys Version: 2024 R1 Error Messages Encountered: During this process, especially when reading the mesh in mhd boundary condition tab, I repeatedly see the following internal error in the console: Error: cx-set-real-entry: wta[2](float) Error Object: ((constant . 0) (profile "" "")) Troubleshooting Steps Already Taken: I have tried to solve this for many days by following a systematic approach, but the issue persists even with a minimal test case (a single conductive block). My troubleshooting steps include: Clean Reinstallation: I have completely uninstalled and reinstalled Ansys 2024 R1 and my graphics drivers. Clean Session: I am running Fluent as an administrator from the Developer Command Prompt and starting a fresh session by reading only the mesh file (.msh), not a potentially corrupt case file. Model Setup: Energy model is ON. The MHD add-on module is successfully loaded, and Electrical Potential is selected. Material Properties: The material for the solid has a valid, non-zero Electrical Conductivity. Cell Zone Configuration: I have confirmed in Models -> MHD Model -> Boundary Condition tab that the correct solid Cell Zone is assigned the conductive material. UDFs: The problem occurs even when no UDFs are loaded. Even after all these steps, the MHD/Potential tab remains disabled in the boundary condition panel. I would really appreciate your helps. Thank you |
| Tags |
| fluent, joule heating, mhd, voltage input |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Exclusivity Issue Running Fluent Using Linux HPC Resources | comiskeyp | FLUENT | 1 | April 16, 2025 10:37 |
| [Commercial meshers] Unknown error when converting fluent mesh to openfoam | Yutao | OpenFOAM Meshing & Mesh Conversion | 0 | April 23, 2023 03:30 |
| How to use the electric potential model in fluent 17? | roadtodream | Fluent UDF and Scheme Programming | 6 | March 2, 2022 07:37 |
| Anode and Cathode in Fluent (Electric Potential) | SanchoBuendia | Fluent Multiphase | 0 | August 7, 2017 16:57 |
| Need help to draweletrical potential by using FLUENT | sayems | ANSYS | 0 | November 21, 2013 06:48 |
