Supersonic Flow to simulate a Normal Shock in a Straight Duct
Old   November 1, 2025, 09:15
Default Supersonic Flow to simulate a Normal Shock in a Straight Duct
Akarsh
AKdfc is on a distinguished road
Hi all,
I am trying to simulate a supersonic flow in a straight duct using ANSYS Fluent with the objective to produce a normal shock as the simulation output and compare the same against normal shock analytical solution.
The flow is assumed to be steady, inviscid and adiabatic.
The boundary condition being imposed at the inlet is a pressure inlet BC with the specification of Total and static pressure values and a pressure outlet BC at the outlet.
I am having trouble firstly initializing the flowfield with a supersonic flow and if it happens so (Standard initialization), the flowfield becomes fully supersonic after a certain number of iterations.
Could anyone suggest what I am missing in the solution setup?
AKdfc is offline   Reply With Quote
duct flow, normal shock, supersonic flows
Normal shock in a ramjet intake. Backpressure imposing. Miguelgh24 Main CFD Forum 15 December 21, 2023 09:58
Supersonic laminar flow over a flat plate ujesha SU2 1 September 25, 2023 18:13
normal shock in convergent-divergent nozzle fhabbio FLUENT 4 April 1, 2017 08:14
Producing a supersonic flow in a constant diameter cylinder clgs.1903 FLUENT 12 May 24, 2012 14:41
Straight duct flow in CFX 5.2 Bo Jensen Main CFD Forum 3 November 25, 1998 07:15
