[Sponsors] | |||||
Unrealistic outdoor humidity (700%) in greenhouse CFD simulation using ANSYS Fluent |
marwane cherkaoui
Rep Power: 4 ![]() |
Hello everyone,
I’m working with ANSYS Fluent 19.2 to study the microclimate inside an agricultural greenhouse. My computational domain includes the outdoor environment, the greenhouse, and vegetation blocks. I have implemented a UDF to model plant transpiration, and I believe it works properly. However, I’m facing an issue: in the outdoor domain, the relative humidity reaches up to 700 %, which is physically unrealistic. Inside the greenhouse, the values are normal. I’m using the Species Transport model for water vapor and the DO (Discrete Ordinates) model for radiation, with the Solar Calculator enabled. In the DO model, I defined two spectral bands: Band 0: from 0.4 to 2.4 µm (solar spectrum) Band 1: from 2.4 to 100 µm (thermal infrared) For the outdoor boundary conditions, I set the temperature to 298 K and the absolute humidity to 0.0119 kg/kg of dry air, which should correspond to a relative humidity of about 58 %. However, Fluent gives an outdoor relative humidity of around 700 %, which is completely inconsistent. If anyone has faced a similar issue or has suggestions (possible error in the DO setup, unit mismatch, or Species Transport configuration), I would really appreciate your help. Best regards, |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ansys Fluent v232 crash on starting | OmarZaki | FLUENT | 8 | July 31, 2024 05:16 |
| numerical simulation with Ansys Fluent of a 3D GORLOV water turbine in two-phase flow | khadija8 | FLUENT | 1 | November 17, 2020 20:32 |
| Moving Shock tube simulation in Ansys fluent | Patelp1996 | FLUENT | 1 | September 11, 2020 05:16 |
| Start new Ansys Fluent Simulation automatically | Malue | Fluent UDF and Scheme Programming | 1 | October 4, 2017 02:48 |
| How to calculate torque of the shaft for turbines in CFD fluent simulation ? | jeevmech | FLUENT | 0 | September 25, 2016 00:30 |
