How to implement adaptive time stepping in ANSYS Fluent journal file for HPC batch ru
Old   November 10, 2025, 08:11
Default How to implement adaptive time stepping in ANSYS Fluent journal file for HPC batch ru
Divya
Disha11 is on a distinguished road
Hello everyone,
I am running unsteady laminar combustion simulations in ANSYS Fluent (version 2024) on an HPC cluster using a pressure-based solver.
Currently, my simulation uses a fixed time step defined in the journal file.
I would like to make the time step adaptive, so Fluent automatically adjusts it depending on convergence or flow stability.
I have already gone through the Fluent User Guide and tried the GUI-based option for “Adaptive Time Stepping”, but I need a way to enable and control it through a journal file or in batch mode since I submit jobs through a scheduler on HPC (no GUI).
My main questions are:
  1. How can I enable or control adaptive time stepping using TUI commands or journal syntax?
  2. Is there a way to write a Scheme script or UDF that adjusts the time step dynamically based on certain conditions?
Here’s what I’ve tried so far:
  • Manually adjusting time steps in the GUI to observe how Fluent changes them under adaptive mode.
  • Searching through TUI commands and Scheme files but couldn’t find documentation on adaptive time step control.
  • Running small tests with fixed and varying time steps to compare convergence behavior.
Disha11 is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
