newbie questions on fluent file management
Old   November 15, 2025, 00:39
Default newbie questions on fluent file management
Sam
Sam-I-am is on a distinguished road
I am a newbie to fluent but new to cfd. I have run many other cfd packages but I have to say that ansys fluent file management is very confusing to me.
I ran a simulation for awhile. In WB, when I click on Setup, it says all data isn up to date and no attention is required. Then when I try to open solution it says: "Upstream data for this cell has changed. Do you want to refresh this cell using upstream ....". It does not seem to matter whether I click yes, no or cancel.
Let us say I want to continue the simulation with a change in BC. Do I need ot go back to the Setup module or can i just change it in the solution module ? I do not want to re-initialize but just continue the solution.
I am using 2025 R1. Thanks
Sam-I-am is offline   Reply With Quote
file reading, file writing, work flow
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
