Handling Flow Reversal
Old   November 17, 2025, 07:33
Default Handling Flow Reversal
yahale
yayale is on a distinguished road
I am simulating airflow inside a tube. The flow is a sinusoidal flow, flow rate starts negative and ends as positive flow rate. (periodic flow).
The problem is that at reversal, the solution is diverging.
What solutions are there for such flows ?
I tried adaptive time step, and tried decreasing time step, both did not work.
Boundary conditions:
Pressure outlet at one end (zero gauge pressure).
Mass flow inlet at the other end (sinusoidal).
Attaching residuals and mass flow rate plots. Instabilities are clear at flow reversal regions.
yayale is offline   Reply With Quote
divergence, fluent - udf, reversal
Questions about FLOW 3D modeling capabilities Dr Youssef Hafez FLOW-3D 0 January 7, 2023 12:37
Visualising Compressible Flow s34n Main CFD Forum 0 October 23, 2022 14:53
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
