[Sponsors] | |||||
How to extract velocity values on a complex surface |
Rep Power: 0 ![]() |
I am using ANSYS Fluent to investigate the airflow reaching a plant model. I would like to check whether the velocity reaching the plant leaves is uniform, so I need to obtain the velocity values at every node on the plant’s surface. Is there a way to extract velocity data from all nodes on a complex surface in Fluent? Thank you. |
| Tags |
| #fluent #data export |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
| Extract 2D velocity values | zalho | FLUENT | 9 | June 2, 2017 06:23 |
| VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
| Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 04:59 |
| Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 14:12 |
