Homogeneous Turbulence in 20L Sphere Dust Explosion Simulation
Old   November 19, 2025, 05:39
Question Homogeneous Turbulence in 20L Sphere Dust Explosion Simulation
tima
timahaffar is on a distinguished road
Hello everyone,
I’m currently simulating a 20-L spherical dust explosion chamber and I’m facing an issue with turbulence prediction. In all published work and experimental references, the flow inside the 20-L chamber should show a strongly turbulent, non-homogeneous region, especially near the ignition zone and around the dispersion nozzle.
However, in my simulations, the turbulence field always appears almost completely homogeneous, regardless of what I change.
Model and setup
k-ε model (standard and realizable both tested)
Mesh refined near the nozzle
Checked boundary conditions (no-slip walls)
Domain is exactly a 20-L sphere with the same nozzle geometry used in published studies
The issue:
TKE values are high, but the spatial distribution is unrealistically uniform no matter what I change.
Question:
What could cause this artificially uniform turbulence? Are there known pitfalls when modeling turbulence in small explosion chambers?
Thanks
timahaffar is offline   Reply With Quote
Validation of homogeneous turbulence with constant shear for RANS models GeorgS OpenFOAM Running, Solving & CFD 2 August 30, 2018 16:11
how to set URANS turbulence model in unsteady flow simulation TimLiu OpenFOAM Pre-Processing 0 April 25, 2017 09:52
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
Turbulence Intensity Vs CFD Simulation Apple L S Chan Main CFD Forum 3 December 15, 1998 18:28
