[Sponsors] | |||||
Solution divergence issues at low pressure ratios for supersonic nozzle simulations |
Rep Power: 0 ![]() |
Hey y'all, I've got a project for my compressible aerodynamics class where I have to simulate 12 different flows each for a converging-diverging and converging supersonic nozzles based on given inlet stagnation and outlet static pressures from some experiments my professor did a while ago.
For the simulations with low pressure ratios, I've been having issues where the solution starts really diverging, and get some fairly unrealistic results (e.g. considering NC State still exists, I can assume Mach 311 flow did not occur). It's a 2D axisymmetric inviscid density-based flow simulation with ideal-gas air (default material properties) with the energy equation, all other models disabled. Inlet face is set as a pressure-inlet zone set so that both gauge and suspersonic gauge pressure are the given inlet pressure for a state, and the outlet face is set as a pressure-outlet zone with the gauge pressure set to the given outlet pressure as a static pressure. Any ideas on either making it behave more nicely or at least limit how unrealistic it gets? The states I'm having the most trouble with: Stagnation temperature T0 = 295 (Degree K) Converging Nozzle Stagnation Pressure at Inlet, P0 = 29.21786 (psi, absolute) Static Pressure at Outlet, Pstatic,out = 29.21787 (psi, absolute) Converging-Diverging Nozzle Stagnation Pressure at Inlet, P0 = 29.56062 (psi, absolute) Static Pressure at Outlet, Pstatic,out = 29.56593 (psi, absolute) Thanks!
"Theseus" Sim PC Specs: OS: Rocky Linux 8.10 Software: ANSYS 2024R1 CPU: AMD Ryzen 5 1600 6-Core GPU: AMD R9 270X 2 GB RAM: 2x8 GB 2400 MHz DDR4 |
| Tags |
| nozzle simulation |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 06:40 |
| divergence error in pressure termal couple | rezvani | Fluent UDF and Scheme Programming | 6 | January 28, 2021 00:54 |
| what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
| Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
| Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
