Problem with compressible fluid density
Old   December 3, 2025, 09:49
Default Problem with compressible fluid density
Jérémy
Beni7kujaku is on a distinguished road
Hello, newbie at Fluent here.
I was trying to do a simple simulation of a pipe (axisymmetric, 1mm from the axis, 400mm long) through which went some o2 (oxygen) slowly (mass flow inlet 1e-5 kg/s).
However, when I changed the density of the oxygen from constant to ideal-gas in Materials, then ran the simulation, the density of the fluid jumped from 1.3kg/m3 (what I would expect from oxygen at 1 bar and 300K) to almost 2.6kg/m3.
The plots for temperature and static pressure are almost constant at 300K and 1.00e+05 Pa, but the absolute pressure is 2e5Pa. I suppose the density difference is because the operating pressure is set to 1 bar, but I can't see where I can change that.
Can you help me?
Beni7kujaku is offline   Reply With Quote
Old   December 4, 2025, 04:18
LYD
LiuYD is on a distinguished road
Can you help me?
Hi Beni7kujaku
I don't use Fluent very often either, but I remember adjusting the operating pressure. It can indeed affect the density of the gas. The specific place for the modification should be at the boundary condition interface. You can refer to the picture I provided.
LiuYD is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
convergence problem with compressible flow sarah l FLUENT 0 July 1, 2015 16:47
Need advice for compressible fluid simulation houkensjtu OpenFOAM Running, Solving & CFD 0 February 2, 2014 08:15
CFD-ACE compressible flow convergence problem DelphineL Main CFD Forum 1 October 21, 2009 06:50
