[Sponsors] | |||||
Haitham Osman
Rep Power: 8 ![]() |
Hi
I am using ANSYS Fluent (Linux version). How to set the automatic export in the journal file using text user interface commands. Thanks in advance Last edited by Haitham Osman CFD; December 3, 2025 at 22:21. |
Alejandro Valeije
Rep Power: 13 ![]() |
/file/start-journal your_journal.jou I think this should do the trick. Kind regards |
Haitham Osman
Thank you so much for your reply Alejandro !
I found this way which helped me /file/transient-export ascii ./file_dir surface_name () pressure density temperature () yes no yes "flow-time" 0.5 flow-time 4 ## take care of spaces between words ## () is necessary and means no more surface or variables. |
You can put surface name inside the parentheses as well
Something like this (surface-name) or with wildcard (*) <—- will select all available surface/plane or like this (ns_inlet*) <—- select surface with prefix ns_inlet |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 08:30 |
| A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 01:17 |
| ansys fluent v16.0 :problem whit resume calculation and automatic export file | ca3tiel | FLUENT | 0 | May 29, 2016 20:08 |
| FLUENT 15 - Data Export | Ari | FLUENT | 0 | February 19, 2016 14:04 |
| Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
