Perforated Heatsink Analysis Boundary conditions Error
Old   December 7, 2025, 00:48
Default Perforated Heatsink Analysis Boundary conditions Error
Sarath Chandran R
Sarath Chandran R is on a distinguished road
I am trying to complete my final year project as a Mechanical Engineering student on the topic, "Heat dissipation through perforated aluminum fins".
I validated a forced convection study in my system and has started performing my own analysis. On my already created heat sink geometry(for paper validation), I added circular perforations and tried to run the same simulation as i did for the paper I validated. What I mean by that is that I didn't do any additional steps for my analysis other than modifying the geometry (no subtraction to create fluid domain for air to pass through as I had already done it initially). The meshing went smoothly but as I entered setup I encountered a problem. For the modified geometry i had two or more extra boundary condition options compared to the initial one. These are interfaces(I think) for which i don't know which option to choose from. I usually go for 'coupled' option in such cases but that option isn't available. I have been stuck here for days now and my runs have been unsuccessful.
So I have a few questions.
1. Can I not use the same geometry used for paper validation and modify it to my needs, should I do my analysis from scratch and do subtraction process(since geometry is different)
2. What should I do about the extra options in Boundary Conditions.
3. Is there anything else I need to be aware of in this scenario.
Sarath Chandran R is offline   Reply With Quote
circular perforations, fluent setup, forced convection, heatsink analysis
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
