warning in fluent as simulation centrifugal fan
Old   December 7, 2025, 10:22
Unhappy warning in fluent as simulation centrifugal fan
xyz
xy99 is on a distinguished road
Hi, I'm new to fluent. When simulating a fan in Fluent, I encountered a warning. Is there someone can tell me How should I fix it? I've been searching through the GUI and TUI for a long time, but couldn't find any access to modify rpvar.
Thank you
WARNING: Sided area vectors require sided centroids. Please set the rpvar nonconformal/use-parent-centroid? to #t and recreate the mesh interfaces.
xy99 is offline   Reply With Quote
interface, rotor-stator, rpvar
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 18:46
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
