Turbulent model impact on heat transfer (HTC)
Old   December 16, 2025, 06:18
Default Turbulent model impact on heat transfer (HTC)
Seongmin LEE
Seongmin is on a distinguished road
Hello guys, I have been doing some simulations to predict HTC of solid parts (composites) inside a fluid domain (autoclave).
I have encountered a problem in which I consistently obtain an overpredicted HTC when using k-w SST turbulent model while the result with Spalart-Allarmas is in the same magnitude with the experimental data.
For example,
If the experimental data is 70W/m^2K.
I obtain:
- 75-80 with S-A turbulent model
- 110 with k-w SST model
My geometry represents the real one, the mesh quality is good, max y+ near the observing solid is 3 (decreased it to 1 but no improvement) and everything seems good.
In this case, I have some questions:
- Should I modify some k-w SST constants?
- k-w SST uses 2 eq instead of 1 (S-A), is it possible that S-A returns a more reliable result?
- Is the case, can I trust S-A model result at least ?
Seongmin is offline   Reply With Quote
htc, turbulent models
How to Implement an Algebraic Turbulent Heat Flux Model in FLUENT George_J FLUENT 0 May 12, 2022 04:39
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
