cleanroom design with fluent
Old   February 12, 2000, 08:33
Default cleanroom design with fluent
KIAN
What are the most common value to use for the turbulent intensity and length scale when using K-e model in a cleanroom air flow. The air speed is at 0.4m/s. Doesn't is need to set up the gravity too. It is running in 2-dimension and the height is at about 3m and width at 4.6m.What boundary codition should I be using, currently I am using velocity-inlet as my inlet and pressure-outlet as my outlet. My outlet length is about 0.28m and inlet at 1.5m, and it is located at left hand corner of the ceiling and right hand corner of the ceiling respectively. The flow should be a u-shape. But my data in the fluent for the velocity do not match with the physical experiment data. Please tell my problems. Need help desperately. I am working on my final year project.
Old   February 15, 2000, 05:11
Default Re: cleanroom design with fluent
María Elena Rodríguez
No, I think it`s not necessary to set up gravity. Elena
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
How to import CAD into Fluent (Design Modeler)? shadyenany FLUENT 2 August 9, 2011 20:14
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
CANDU steam generator design in fluent Faisal Bashir FLUENT 0 September 10, 2007 01:03
